Question [Topic closed by moderator - lack of interest] problem posting
16 years 7 months ago #44458 by Cerberus
Replied by Cerberus on topic Re: problem posting
yer it will be in your webservers php error log file. i seee you have joomsocial installed try disabling that and see if it works, i have heard of people having issue with it..
16 years 7 months ago #44463 by spuki
Replied by spuki on topic Re: problem posting
doit, but not, i has the same error
16 years 7 months ago #44466 by Cerberus
ok try using
defualt_ex template for kunena and rhuk_milkyway template for joomla
and see if its works then, cause rocket themes have been know to course issues too
16 years 7 months ago #44468 by spuki
nop, dont work
16 years 7 months ago - 16 years 7 months ago #44470 by Cerberus
only other thing left it to disable ur modules one by one till it works or give me admin access and it will see if i can spot the error in the backend for u.
Last edit: 16 years 7 months ago by Cerberus.
16 years 7 months ago #44480 by sozzled
Replied by sozzled on topic Re:problem posting
This is obviously a test website. The user appears to be simultaneously evaluating Kunena, ccBoard and Agora forums. Good luck!
The only things that I can see, based on the most superficial view, is that the user has K 1.5.11 and is using the default_ex Kunena template. The user is using a RocketTheme site template and the user has no idea what a rhuk_milyway template looks like. It's my guess that there's a RocketTheme plugin (like RokCandy) that's causing the problem. I can't see anything else that's immediately obvious, though.
