Question Emoticons problem
16 years 8 months ago - 16 years 8 months ago #41457 by Sasha
Emoticons problem was created by Sasha
Hi.
I have a problem with emoticons. Checked permissions, everything seems to be ok. Take a look at preview (Test). Same thing happens after posting/editing etc, they are blank. When I do RClick -> View image, url is correct, but again, no emoticon. I've tried 4 or 5 templates (Including default_ex), but no results.
Sorry for "my" english.
Thanks in advance.
Last edit: 16 years 8 months ago by sozzled. Reason: fixed spelling
16 years 8 months ago #41459 by sozzled
Replied by sozzled on topic Re:Emoticons problem
What version of Kunena are you using and what Kunena template are you using.
Sometimes this problems occur because of a conflict with another Joomla extension. For example, the RokCandy plugin is often responsible for issues like this.
16 years 8 months ago - 16 years 8 months ago #41484 by Sasha
Replied by Sasha on topic Re:Emoticons problem
Hi, thanks for reply.
I'm using Kunena 1.5.9 (Default_ex) integrated with CB 1.2.1 and no, I do not use RokCandy. Maybe because of yooeffects, but I doubt about that?
If you want, I can PM you with the list of extensions I currently use?
Last edit: 16 years 8 months ago by Sasha.
16 years 8 months ago #41487 by xillibit
Replied by xillibit on topic Re:Emoticons problem
You can take a look of conflicting plugin page : docs.kunena.com/index.php/Conflicting_plugins but I'am not sure that the issue come from to a javascript conflict.
When you hit the emoticons buttons, are there added in textearea ?
When you put the url of the emoticons in on new page of you browser, do you see your emoticon ?
Maybe you can give a link to your site with a test account, but i'am pretty that it's a permissions problem.
16 years 8 months ago #41493 by Sasha
Thanks for reply xillibit.
Maybe you're right about permissions.
Heres the url
UName: Proba
Pass: testing
16 years 8 months ago #41495 by xillibit
I have checked your site, and it's a permissions issue, so check the permissions on all the files in the directory : components\com_kunena\template\default_ex\images\english\emoticons
