Important [Topic closed by moderator due to lack of interest] Help my Forums might be deleted?
16 years 2 months ago - 16 years 1 month ago #40160 by sapperk
Ok i was messing around with the topics in my forums. I took the main category and changed the parent to something else and now my forums arent all gone. I know im not explaning this correctly am i?
Last edit: 16 years 1 month ago by sozzled. Reason: Topic closed
16 years 2 months ago #40165 by sozzled
OK, calm down. Do you have a backup of your website before you made those changes?
Have a good look at the Forum Administration panel to see where you have moved things around.
I assume that you did not make any changes to the database (with something like phpMyAdmin, for example).
Work with us on this problem and your site will be back again in no time. :)
16 years 2 months ago - 16 years 2 months ago #40171 by sapperk
:) Im always messing things up :P
No backup, my website host doesnt do back ups and I didnt back anything up either. Let me try to explain this better what I did:
1. I was looking at all the Categories and Forums in the Admin Panel. You know where you can add new categories and stuff and set controls for them?
2. The first Category had no Parent Directory, I guess it is called. And I wanted to just see what would happen if I changed the Parent Directory to I guess it was the Forum Name or something? Not really sure how to explain it.
3. Went to more forums to see what it would change and now all my Categories and Forums in them are hidden somewhere. Im sure they are still in the DataBase on my Host but I have no idea how to roll it back or to retrieve the way it was.
4. Is there an option in the Kunea Forums to roll back or something?
5. Its now telling me when i go to forums that there are no categories.
Here is link to my website: Website
User name: test12
Password: test12
Last edit: 16 years 2 months ago by sapperk.
16 years 2 months ago - 16 years 2 months ago #40192 by sozzled
Username/password = test12/test12 is invalid
There is a lesson here: if you're unsure about what something might do, make a backup before you start experimenting. Better yet, try things out on a test website before you touch your production website. Having a good backup régime is your responsibility, no-one else's! Before you do anything else, right now, download Joomlapack and read how to use it . Experiment with it on a test website. Get comfortable with it. OK? ;)
Kunena does not have the kind of roll-back feature that you're looking for. It still should be possible to repair the damage.
Because you created the problem at the back-end, the problem can only be fixed at the back-end. I understand that it's necessary to have a username/password to see your forum but, if you want my help, I will need a username/password as a site manager or administrator to do any good. Please do not post that information here publicly. It would be better if you PM the information to me (if you trust me, that is). ;)
16 years 2 months ago #40193 by sapperk
I sent you a PM B)
16 years 2 months ago #40196 by sozzled
Username = test12 (all lowercase letters "t" "e" "s" "t")
Password = (as above)
This is not a valid username/password combination. I am not a mind-reader. Please provide the correct information. Thanks :)
Time to create page: 0.298 seconds
