Question SEO/SEF problems
16 years 9 months ago - 16 years 9 months ago #40041 by SEOLord
SEO/SEF problems was created by SEOLord
I finaly got rid of any SEF component! Thank god :laugh: , but I'm having a small SEF problem, :unsure: my kunena links show like www.domain.ro/component/kunena/forum-name/ with SEF enabled, any chance you guys have an ideea how to fix this?
I have SEO enabled, htaccess, kunena seo enabled, cache cleared...donnow why it shows up like this, I can redirect /component/kunena to /forum, it works, but I would prefer a non redirect 301 option.
Am I missing something here? Thank you very much!
Last edit: 16 years 9 months ago by sozzled. Reason: Change topic subject for relevance
16 years 9 months ago #40077 by xillibit
try to change the alias of the kunena menu item in joomla! in the menu manager with like you want.
16 years 9 months ago #40119 by SEOLord
Hello, thanks again for your replay!
I got "forum" and I tested with "board" and got the previos behavior with no links working. :(
It seems like this is the only way , to have alias forum, the forum to put component/kunena and me to rewrite with htaccess [r301] as forum/ :(
Any other ideea? :unsure:
16 years 9 months ago #40143 by SEOLord
variable value $0 " key value $file "/home/xxx/public_html/components/com_kunena/template/default/post.php" $line "242" $function "trigger_dberror" [args] Nested Array " $1 " key value $file "/home/xxx/public_html/components/com_kunena/kunena.php" $line "581" [args] Nested Array $function "include" " $2 " key value $file "/home/xxx/public_html/libraries/joomla/application/component/helper.php" $line "162" [args] Nested Array $function "require_once" " $3 " key value $file "/home/xxx/public_html/includes/application.php" $line "124" $function "renderComponent" $class "JComponentHelper" $type "->" [args] Nested Array " $4 " key value $file "/home/xxx/public_html/index.php" $line "68" $function "dispatch" $class "JSite" $type "->" [args] Nested Array " Installed version: Kunena 1.5.9 | 2010-01-23 | 1869 [ Susurrate ] | php 5.2.11 | mysql 5.0.89-community
When I click post I get this error :( nothing gets posted :(
16 years 9 months ago #40146 by xillibit
Replied by xillibit on topic Re:Hell -P
Enable the debug in joomla! configuration panel and tell me the detailled error message.
16 years 9 months ago #40392 by SEOLord
Replied by SEOLord on topic Re:SEO/SEF problems
No need, I'm letting it go, gonna re-activate my SMF forum, I'm sorry, just...to many problems, this component looks great, just doesn;t like my joomla install.
Good luck guys and thank you for your support!
