Question [SOLVED] problems with avatars
  • lalakios
  • lalakios's Avatar Topic Author
  • New Member
  • New Member
16 years 9 months ago - 16 years 9 months ago #39461 by lalakios
[SOLVED] problems with avatars was created by lalakios
hello everybody....i need your help pleas...........
i have no idea of what's wrong with avatars.....i 'm trying to set an avatar from the default gallery,nothing shows....so i cannot select from it!
Also,i 'm trying to upload an avatar from my pc,and still nothing happens!
(I use the latest version of kunena...just installed it)
Is there a fix about it? you'll save my day!
Last edit: 16 years 9 months ago by lalakios.
16 years 9 months ago #39465 by xillibit
16 years 9 months ago #39470 by sozzled
Replied by sozzled on topic Re:problems with avatars
xillibit's advice deals with the avatar upload problems. :)
There is a known problem with K 1.5.8/9 - it's mentioned in 1.5.9 - Known issues - dealing with the built-in avatar gallery: see Avatar not display in Kunena 1.5.9
  • lalakios
  • New Member
  • New Member
16 years 9 months ago #39471 by lalakios
Replied by lalakios on topic Re:problems with avatars
well,i miss this folder /media/kunena/attachments/legacy as i can see...........but why isn't there?
kunena succeded at installation...no errors!
16 years 9 months ago #39472 by xillibit
Replied by xillibit on topic Re:problems with avatars
I don't know, so just create the dir \joomla\images\fbfiles\avatars with the good permissions.
