Question Kunena dont work with multilanguage web (444 - component not found)
16 years 10 months ago #37537 by spindy
Hello.
I have a multilanguage web (English-Spanish) and my problem is Kunena dont work with Spanish language.
We use the module mod_jflanguageselection for change language.
If the web is in english Kunena work, but if you change the web to Spanish.. Kunena dont work. It say "444 - component not found".
PD: We have a kunena.spanish.php and kunena.english.php in \administrator\components\com_kunena\language\
What is the problem? We need the forum work in both languages.
16 years 10 months ago #37544 by xillibit
I have just tested now, this works, try to disable sef if you using it.
16 years 10 months ago #37548 by spindy
I did disable Kunena SEO Settings and it dont work.
Then i did disable Seo in joomla global configuration too and it dont work either.
When i clik on Kunena Menu Item in Spanish language it say me "444 -component not found" :(
16 years 10 months ago #37551 by xillibit
Is there a difference to the link to the Kunena component when you set english when you set spanish ?
16 years 10 months ago #37552 by spindy
Ok.
I fix it. Now work.
It was not Kunena problem. Joomfish Forum-menu spanish traslation had a link with my previus phpbb3 bridge.
Now work well. Thank and sorry for the nuisances.
16 years 10 months ago #37554 by spindy
Yea that was the problem. Thanks :)
