Question Forum looping / going to same thread when clicking on others
When I first was trying to click into threads I got some browser time out / loop thing so you couldn't click into threads.
There is also an issue now when you click into threads and it gives you the one you first clicked into. You cant access others.
If someone could check it out and point me in the right direction that would be great.
Also check to see if you get the same thing after trying to click around the forum or post.
Thanks.
Site is.
www.phototalk.net.nz
Has anything changed?
You should first upgrade to K1.5.8 (you have K1.5.4, which has over 100 bugs which have been fixed).
So that is one possible cause of that eh? I will double check nothing has been chnaged... anything else that could cause that?
I will get onto the upgrade ASAP.
Thanks for the feedback.
I just tried to post now in the forum and cant even click into a thread. Pretty major really as it may put people coming back to post.
Anyone else got some feedback or suggestions?
Thanks.
No, I do not have access to look into this. I assume that upgrading Kunena didn't work..?
You can contact me by Skype (icon in my profile, just look ->)..
