Question Problem with Avatar..
16 years 11 months ago #34525 by christos7k
please help...i upload a image 1mb and i have this fatal error... (Fatal error: Allowed memory size of 33554432 bytes exhausted (tried to allocate 10240 bytes) in /home/pcstylec/public_html/components/com_kunena/template/default/plugin/myprofile/myprofile_avatar_upload.php on line 297)
please help..
16 years 11 months ago #34529 by xillibit
Replied by xillibit on topic Re:Problem with Avatar..
What kunena version do you using ? Try to increase the memory_limit and max_execution_time in your php.ini file.
16 years 11 months ago #34550 by christos7k
Replied by christos7k on topic Re:Problem with Avatar..
i have 1.5.7..how to do this? (increase the memory_limit and max_execution_time in your php.ini)
16 years 11 months ago #34552 by xillibit
The file php.ini is on your webserver, but i don't if you have access to it. Then, you need to increase the variables following : memory_limit and max_execution_time
For example, for memory_limit set :
memory_limit = 128M
and for max_execution_time
max_execution_time = 30
16 years 11 months ago #34553 by christos7k
ok i will try this...thanks my friend...
16 years 11 months ago #34574 by christos7k
Sory for my question but i can;t find the php.ini... where is it?
