Question boardcode HELP!
vixenmafia.com
I have a problem with the boardcode screen.
example
Im using the "dragon back template"
When some wants change color of the text the colors do not show up...?
How do i fix this?
can you give me please a access ot your because it's restricted to users registred only. Do you have tried with default_ex template ?
I have set it to NO at this time.
You should be able to access the forums and see what i mean. If not can you just login with username: test Password: red555
This for anyone that thinks they might be able to help.
Please i need some help asap.
geez what kind of support is this ?
Nobody KNoWs anything?
Come on what a joke.
This looks like css issue and either you have partially fixed it by changing background to white or you have changed the template.
If you have further questions, please contact the author of your template, so that he can fix it for everyone.
