Question Upgrade/Migration Problem
17 years 1 month ago #31365 by Otter
I am currently migrating from Joomla 1.0.15 to Joomla 1.5. I have downloaded and installed everything from my old site to my new site the only problem i am having is with the Kunena Migration. I have read the migration help and tried to follow it as best as possible. From my understanding it is just a matter of exporting the old sql database jos_fb_* and importing it into the new sql database. i have done that, when i go to test my new site the opening page of the kunena board looks fine (catagoires list) but when i click into any of the catagories i get a busted page with no joomla template and a bad listing.
Here is the error code i get at the bottom of the page
"Installed version: Kunena 1.5.6 | 2009-10-02 | 1806 [ Speaker ] | php 5.2.9 | mysql 5.0.81-community
Fatal error: Unable to load messages.\nDB function reports no errors in /home/****/public_html/j15/components/com_kunena/lib/kunena.debug.php on line 58"
I am very frustrated with this and dont know how to fix it. everything except the post listing page is viewing fine.
17 years 1 month ago #31448 by xillibit
Enable the debug mode in joomla! configuration panel, and check that you have a better error message. Check too that you have all tables beginning by jos_fb_*
17 years 4 weeks ago #31528 by Matias
Replied by Matias on topic Re:Upgrade/Migration Problem
Error handler seems to be broken. This will show the real error message:
File Attachment:
File Name: errorhandler.zip
File Size:1.73 KB
Unzip it in Joomla root directory or copy the file into location specified in the zip file..
17 years 4 weeks ago - 17 years 4 weeks ago #31587 by phutter
Hi matias,
i have the same problem. Also i installed the errorhandler.zip.
Now i become the follow Errormessge:
DB function failed with error number 1054
Unknown column 'moved' in 'where clause' SQL=SELECT a.id, a.thread, a.subject, b.lastpost FROM jos_fb_messages AS a JOIN ( SELECT thread, MAX(time) AS lastpost FROM jos_fb_messages WHERE time >'1253675930' AND hold='0' AND moved='0' AND catid IN (1,2,8,9,10,12,13,14,15,16,17,18,19,20,21,23) GROUP BY 1) AS b ON b.thread = a.thread WHERE a.parent='0' AND a.moved='0' AND a.hold='0' GROUP BY a.thread ORDER BY b.lastpost DESC LIMIT 100
SQL =
SELECT
a.id,
a.thread,
a.subject,
b.lastpost
FROM
WHERE time >'1253675930' AND hold='0' AND moved='0' AND catid IN (1,2,8,9,10,12,13, in /homepages/5/d178495571/htdocs/cms/components/com_kunena/lib/kunena.debug.php on line 152
thx
Peter
Last edit: 17 years 4 weeks ago by phutter.
17 years 4 weeks ago #31598 by Matias
Try to run this SQL:
ALTER TABLE `jos_fb_messages` ADD COLUMN `moved` TINYINT(4) NULL DEFAULT '0' AFTER `hits`, COMMENT=''
But why the field is missing? Which version did you have in Joomla 1.0 and how did you upgrade?
17 years 4 weeks ago #31619 by phutter
Hello Matias,
thank you very much. This SQL - statement was helpful.
Btw. I use kunena at version 1.09(?) under Joomla 1.5x
cu
Peter
