Question Upgrade/Migration Problem
Here is the error code i get at the bottom of the page
"Installed version: Kunena 1.5.6 | 2009-10-02 | 1806 [ Speaker ] | php 5.2.9 | mysql 5.0.81-community
Fatal error: Unable to load messages.\nDB function reports no errors in /home/****/public_html/j15/components/com_kunena/lib/kunena.debug.php on line 58"
I am very frustrated with this and dont know how to fix it. everything except the post listing page is viewing fine.
Enable the debug mode in joomla! configuration panel, and check that you have a better error message. Check too that you have all tables beginning by jos_fb_*
Unzip it in Joomla root directory or copy the file into location specified in the zip file..
i have the same problem. Also i installed the errorhandler.zip.
Now i become the follow Errormessge:
DB function failed with error number 1054
Unknown column 'moved' in 'where clause' SQL=SELECT a.id, a.thread, a.subject, b.lastpost FROM jos_fb_messages AS a JOIN ( SELECT thread, MAX(time) AS lastpost FROM jos_fb_messages WHERE time >'1253675930' AND hold='0' AND moved='0' AND catid IN (1,2,8,9,10,12,13,14,15,16,17,18,19,20,21,23) GROUP BY 1) AS b ON b.thread = a.thread WHERE a.parent='0' AND a.moved='0' AND a.hold='0' GROUP BY a.thread ORDER BY b.lastpost DESC LIMIT 100
SQL =
SELECT
a.id,
a.thread,
a.subject,
b.lastpost
FROM
WHERE time >'1253675930' AND hold='0' AND moved='0' AND catid IN (1,2,8,9,10,12,13, in /homepages/5/d178495571/htdocs/cms/components/com_kunena/lib/kunena.debug.php on line 152
thx
Peter
ALTER TABLE `jos_fb_messages` ADD COLUMN `moved` TINYINT(4) NULL DEFAULT '0' AFTER `hits`, COMMENT=''
But why the field is missing? Which version did you have in Joomla 1.0 and how did you upgrade?
thank you very much. This SQL - statement was helpful.
Btw. I use kunena at version 1.09(?) under Joomla 1.5x
cu
Peter
