Question Problems after updating to 1.5.6.
  • webrus
  • webrus's Avatar Topic Author
  • New Member
  • New Member
17 years 1 month ago #30818 by webrus
Problems after updating to 1.5.6. was created by webrus
After updating Joomla to 1.5.14 I updated Kunena to 1.5.6.
Now I have no access to the component in the Joomla backend:
Fatal error: Class 'fb_config' not found in /var/www/html/joomla/administrator/components/com_kunena/admin.kunena.php on line 26
When I turn of legacy mode I have no acces to frontend and backend:
Direct Access to this location is not allowed.
The German language files I got from here seem to be incomplete. Any better suggestion.
Hope someone can help.
17 years 1 month ago - 17 years 1 month ago #30822 by Lintzy
No, the german language files are NOT incomplete. They work pretty fine, like you can see here: templates.webdesign-welt.de/demo-forum.html . And there are hundreds of (german language file) downloads without reported issues.
If you have installed the changes in timeformat, use the recoverypack und you have the
original kunena files back
I would appreciate it, if you would search the real reason for this issue.
Last edit: 17 years 1 month ago by Lintzy.
17 years 1 month ago #30825 by rich
I have installed this language files now. All functioned correct. Upload this file again, maybe it works after.
Regards
  • webrus
  • New Member
  • New Member
17 years 1 month ago - 17 years 1 month ago #30842 by webrus
Replied by webrus on topic Re:Problems after updating to 1.5.6.
O.K. now as far as to the language files. - The download of the file was incomplete.
Any ideas on the other issues?
Fatal error: Class 'fb_config' not found in /var/www/html/joomla/administrator/components/com_kunena/ admin.kunena.php on line 26
Last edit: 17 years 1 month ago by webrus.
17 years 1 month ago #30849 by xillibit
Try to re-upload the files in joomla/administrator/components/com_kunena and check if you have hacks or something that need legacy mode.
17 years 1 month ago #30853 by Lintzy
If the download is uncomplete, you can not unzip it and install it.
