Question Integration problems with Kunena and CB
17 years 1 month ago #29870 by garyst
I'm building a stage site in my local machine
Joomla version 1.5.x
Community Builder 1.2.1
Kunena version 1.5.5
This are the problems I have...
When I want to edit the rank names I got this
when I try to save as it is I got this
Firefox error console says:
Error: unterminated string literal
Source file: http://localhost/administrator/index2.php
Línea: 345, columna: 29
Código fuente:
document.rank_image.src = "http://localhost/components/com_kunena/template/default/images/english/ranks/\" + newimage;
I can't see in firefox the rank images on this page:
for IE works just fine, this is the error firefox tell me about that
Error: The stylesheet http://localhost/administrator/components/com_comprofiler/plugin/templates/dark/template.css Is not loaded because it's MIME Type, "text/html", is not "text/css".
source file: http://localhost/administrator/index2.php?option=com_kunena&task=ranks
Línea: 0
17 years 1 month ago #29886 by xillibit
This is a known bug in Kunena 1.5.5, for prevent this issue you need to login in the joomla administration with english language.
17 years 1 month ago #29917 by garyst
OK, tried, that solved the first problem, but I still don't see the images on firefox
17 years 1 month ago - 17 years 1 month ago #29944 by xillibit
This is known bug, which has already reported.
You need to have the directory components/com_kunena/template/default/images/Yourlanguage
I have find a little workaround, open the file administrator/components/com_kunena/admin.kunena.html and at line 3437 repalce this :
<td><a href = "#edit" onclick = "return listItemTask('cb<?php echo $id; ?>','editRank')"><img src="<?php echo ($rankpath['live'] .DS. $row->rank_image); ?>" alt="<?php echo $row->rank_image; ?>" border="0" /></a></td>
by this :
<td><a href = "#edit" onclick = "return listItemTask('cb<?php echo $id; ?>','editRank')"><img src="<?php echo ($rankpath['live'] . $row->rank_image); ?>" alt="<?php echo $row->rank_image; ?>" border="0" /></a></td>
In the file administrator/components/com_kunena/admin.kunena.php at line 1995 repalce this :
$path = $path['live'] .DS;
by this :
$path = $path['live'];
Last edit: 17 years 1 month ago by xillibit.
