Question Recount problems
17 years 2 months ago #29402 by Oetzi
Recount problems was created by Oetzi
I just tried to recount the infos of the categories, but I always get an execution timeout. When I edit my php.ini to make it run as long as i want. The script is running and running. Looks realy like a endless-loop.
And all categories show 0 entries.
Perhaps you can help ist very important
17 years 1 month ago #30850 by xillibit
Replied by xillibit on topic Re:Recount problems
17 years 1 month ago #30859 by Oetzi
Replied by Oetzi on topic Re:Recount problems
Hello
I finally found the problem. I have debugged the script and found the mysql-query which result in php endless loop in the recount-function. After doing the query directly on the database i have found an category entry which i have deleted some weeks ago and which was not displayed in the joomla backend anymore but was still inside the database. And this entry had as parent-category itself. So the recursive walk from the childs to the parent ends in a loop on this entry.
I have tried to reconstruct the error with an backup of the database on my testserver and deleted the category there again but everything seemed to work fine there. So I don't no what was wrong on the livesystem. But after deleting the category manual in the database everything works fine now.
