Question [SOLVED] Images don't load and CSS doesn't load correctly. Any idea?
www.loadingreality.com/component/option,com_kunena/Itemid,108/
Does anyone know what is going on here? It just suddenly turned this way. I had installed a new version of JReviews with S2Framework.
:huh:
there is a conflict with that plugin
docs.kunena.com/index.php/Conflicting_plugins
i see u use ROKBOX
Thanks, but I have been using RokBox from the beginning and it hasn't affected my template. Just to be sure, I have disabled it and the forum still doesn't work.
Any other ideas of conflicts?
disable cache if possible
also live it for 10 minute so i can give a look
I believe it has to do with my css files. The ones it is trying to load do not exist on my server.
