Question Posts place themselves on wrong positions - latests published order
17 years 2 months ago - 17 years 2 months ago #28689 by Dade
Hi all!
I noticed a little BIG bug on Kunena Forums which is happening on my both sites independently.
Mainly, if a moderator or admin delete a post - I cant even imagine a whole thread - then the next guy that will post on the forums will occupy that deleted place. For example: User A posts at 20:00, User B at 20:01 and finally User C do it at 20:02. Then the Moderator delete the post of User B as it is not following the rules, and later User D posts again. The post of User D take the place of the User B one, although he posted later.
Anyone knows about this bug? My personal tough is - just supposing - that kunena orders the posts by their ID, therefore when a post is deleted, the next post will occupy that deleted ID. Probably I am wrong, but thats what I think can be the problem.
UPDATE: Just received a message by my community users saying that it seems that problem 'got solved' when hitting Quick Post button. I dont know if it is a coincidence or a solution, because on my clan page, it happened the same and it solved it without doing anything.
I hope I can give my help to this great project submitting this bug. Bye all!
PS: Is this the correct place to post this things?
Last edit: 17 years 2 months ago by Dade. Reason: UPDATE
17 years 2 months ago #28781 by xillibit
Yes it's the right place for bug report.
I have tested now, and I don't encounter this problem. What Kunena version do you use ?
17 years 2 months ago #29437 by Tipex
hello
I have the same Problem. I have delete a lot of Post and after all new Post published on the top .... and not after the other Post.
Have you got a idear what ist the Problem and how i can chance this problem?
talke soon
silvia
17 years 2 months ago #29441 by Tipex
PS: I have make a lot of Poste and know it funktion normal.. its realy a problem of ID...
17 years 2 months ago #29734 by Dade
I am running Kunena 1.5.5 with Joomla 1.5.14 on both sites this is happening - one with an upgraded joomla version and fresh Kunena installation, and the other one from fresh install of joomla and fireboard2kunena export.
There are other components like GroupJive, CB 1.2.1, JAwards 1.0, UddeIM, etc. But I think that is not important.
Thanks for reply!
17 years 2 months ago #29755 by doohan
Dade, I was having this problem and it turns out it that using the default_ex template instead of any of the others fixes it. Apparently those themes are for an older version.
