Question Posts place themselves on wrong positions - latests published order
I noticed a little BIG bug on Kunena Forums which is happening on my both sites independently.
Mainly, if a moderator or admin delete a post - I cant even imagine a whole thread - then the next guy that will post on the forums will occupy that deleted place. For example: User A posts at 20:00, User B at 20:01 and finally User C do it at 20:02. Then the Moderator delete the post of User B as it is not following the rules, and later User D posts again. The post of User D take the place of the User B one, although he posted later.
Anyone knows about this bug? My personal tough is - just supposing - that kunena orders the posts by their ID, therefore when a post is deleted, the next post will occupy that deleted ID. Probably I am wrong, but thats what I think can be the problem.
UPDATE: Just received a message by my community users saying that it seems that problem 'got solved' when hitting Quick Post button. I dont know if it is a coincidence or a solution, because on my clan page, it happened the same and it solved it without doing anything.
I hope I can give my help to this great project submitting this bug. Bye all!
PS: Is this the correct place to post this things?
Yes it's the right place for bug report.
I have tested now, and I don't encounter this problem. What Kunena version do you use ?
I have the same Problem. I have delete a lot of Post and after all new Post published on the top .... and not after the other Post.
Have you got a idear what ist the Problem and how i can chance this problem?
talke soon
silvia
There are other components like GroupJive, CB 1.2.1, JAwards 1.0, UddeIM, etc. But I think that is not important.
Thanks for reply!
