Question Topics, Replies = 0, Last Posts = No Posts even though there are several posts....
17 years 3 months ago - 17 years 3 months ago #27448 by kdpickett
We have just launched our forum site. After putting in several posts, it still shows that Replies and Topics equal to 0. The Last Posts column equals to No Posts. If you look at the Category Title, you will see "1 New" or "2 New", etc. whatever applies to that category. I have searched the forum and performed the "Recount Category Stats" function. That doesn't seem to affect this problem.
Our forums are located Here
Joomla Version: 1.5.13
Kunena Version: 1.5.4
Any help would be greatly appreciated.
Keith
Last edit: 17 years 3 months ago by kdpickett. Reason: spell correct
17 years 3 months ago #27466 by Matias
Has your forum been private when you wrote those messages? I'm trying to locate similar bug for private forums.
Which PHP/MySQL versions do you have?
Try to enable debug mode before posting a new topic and reply to see if errors get reported. Did you get any error message?
17 years 3 months ago - 17 years 3 months ago #27541 by kdpickett
No. We do not have any private forums.
PHP Version 5.2.8
MySQL Server version: 5.0.81-community MySQL Community Edition (GPL)
[strike]Do you mean enable Debug mode in Joomla or is there something in Kunena that I missed?[/strike]
Nevermind. I have attached two txt files. One is a debug dump of the categories listing on the frontend where the problems shows up and the second one is a debug dump of the recount category stats function.
Thanks for responding.
-Keith
File Attachment:
File Name: debugdump_...list.txt
File Size:26.71 KB
File Attachment:
File Name: debugdump_...tats.txt
File Size:8.82 KB
Last edit: 17 years 3 months ago by kdpickett. Reason: adding debug file dumps
17 years 3 months ago - 17 years 3 months ago #27547 by kdpickett
I went back and re-read your post about debugging. When I post a new topic, it submits and refreshes too fast for me to capture the debug. I was able to reply to the message and capture that debug dump. There were no errors or anything obviously wrong that I could tell (see attached).
Is it possible that there is some sort of UNIX timestamp issue causing this? I noticed the SQL referencing a timestamp in one of the queries from the debug. The reason I ask is that sometimes after I post, it will show 1 post in the category list and the name of the subject header for the host. At some point later, I can come back and refresh the categories page and the post and replies are set to 0 again and the Last Post field is empty.
Thanks,
Keith
Attachment debugdump_frontinsideforumreplyt.txt not found
Last edit: 17 years 3 months ago by kdpickett. Reason: Adding more info
17 years 3 months ago #27571 by Matias
Adding that last message changes last message, and topic & post count to 1 from both category 1 and 20. It also increases message count from your user. But I don't understand why these counters will get updated again so that you will get 0 messages..
I already see potential problem in these queries, but they do not explain why the value gets reseted..
If you want to debug more, please look for UPDATE queries when you will loose the counter information..
17 years 3 months ago #27621 by parisz
Same problem here after fresh install.Our forum is located in podilatespatras.org/index.php?option=com...emid=13&func=listcat (unfortunately it's in greek).Any advice?
