- Thank you received: 1
Question messages not displayed in categories and statistics
I'm making some progress....
Using your advice I managed to find out that there was a problem with my kunena configuration. In RECENT POST SETTINGS the number of SHOW CATEGORY should had been left blank to have access to recent postings.
That let me with one problem to sort out: The categories are still not counting the new messages. Is it because of my settings?
I don't think that your problem comes from to a configuration problem, but you can check this page with some tips for the configuration : docs.kunena.com/index.php/Configuration_Tips
You haven't answer to my question, what kunena template do you use ?
In Kunena configuration panel, you can try : recount category stats
Many thanks for your message.
To date, I only have one big issue to work on: the number of subjects and replies are not displayed in the categories page.
I did try the recount category stats in the Kunena configuration panel.
>>Result: in the back end: error message, in the front end: all counts of messages in the categories are wiped out.
I'm using the French version of kunena 1.5.5:
kunena.aide-joomla.com/telechargement.html?func=fileinfo&id=34
And my chosen template is: dorona15_ex
I will try your link to kunena documentation page.
I'll let you know.
Cheers
Could this be the problem?
