Question [SOLVED] Problem with ranks
When trying to add a new rank, I can't complete the Add new process because one parameter is missing. I think it's something related with the image associated with the rank. When I try to edit one created rank, the image didn't show up (and gave me the same missing parameter error). I've attached one image, hope it helps.
Thanks!.
I've copied the images from:
/components/com_kunena/template/default_ex/images/english/ranks
to:
/components/com_kunena/template/default_gray/images/english/ranks
Thanks in advance Sozzled
Edit: In the Kunena Configuration page, the images are set in 'default_ex' and I've checked that the rank images are present in that folder
On the FireBoard Ranks management, when tried to Add new rank, it gave me this error
Warning: Invalid argument supplied for foreach() in /home/goyomart/public_html/administrator/components/com_fireboard/admin.fireboard.php on line 1978
The configuration is the same on Fireboard and Kunena (maybe i need to delete Fireboard component?).
I had already seen this issue before but no solutions has been found, so I will report this to the DEVs.
As far as your use of default_gray template is concerned, please read There is only one endorsed and supported Kunena template ; there's a good chance that there's no solution if you use the default_gray template. I have found that it's necessary to copy the rank images from the default_ex folder to the default folder.
As far as simultaneous installation of Kunena and Fireboard on a single website is concerned, I have it on good authority that you can't do that. Uninstall Fireboard.
Thanks for the help Sozzled and Xillibit
