Question [SOLVED] Problem with ranks
17 years 3 months ago - 17 years 2 months ago #26688 by Tanin
Hi!, after a quick view on the forums (and didn't find anything related) I post my problem with the ranks (kunena 1.5.5, joomla 1.5.9)
When trying to add a new rank, I can't complete the Add new process because one parameter is missing. I think it's something related with the image associated with the rank. When I try to edit one created rank, the image didn't show up (and gave me the same missing parameter error). I've attached one image, hope it helps.
Thanks!.
Last edit: 17 years 2 months ago by Tanin.
17 years 3 months ago - 17 years 3 months ago #26689 by sozzled
Replied by sozzled on topic Re:Problem with ranks
Please read Ranks Management in the Wiki. You have to upload your rank images before you can assign them. :)
Last edit: 17 years 3 months ago by sozzled.
17 years 3 months ago - 17 years 3 months ago #26693 by Tanin
Replied by Tanin on topic Re:Problem with ranks
I want to use the same images in default_ex. I've copied and created the same structure but i don't see where I need to change the path in the kunena configuration panel to read the new folder.
I've copied the images from:
/components/com_kunena/template/default_ex/images/english/ranks
to:
/components/com_kunena/template/default_gray/images/english/ranks
Thanks in advance Sozzled
Edit: In the Kunena Configuration page, the images are set in 'default_ex' and I've checked that the rank images are present in that folder
On the FireBoard Ranks management, when tried to Add new rank, it gave me this error
Warning: Invalid argument supplied for foreach() in /home/goyomart/public_html/administrator/components/com_fireboard/admin.fireboard.php on line 1978
The configuration is the same on Fireboard and Kunena (maybe i need to delete Fireboard component?).
Last edit: 17 years 3 months ago by Tanin.
17 years 3 months ago #26714 by xillibit
Replied by xillibit on topic Re:Problem with ranks
I had already seen this issue before but no solutions has been found, so I will report this to the DEVs.
17 years 3 months ago - 17 years 3 months ago #26738 by sozzled
Tanin: As far as K 1.5.5 is concerned, I haven't yet tested whether the ranks management features are different to the way they worked in K 1.5.4.
As far as your use of default_gray template is concerned, please read There is only one endorsed and supported Kunena template ; there's a good chance that there's no solution if you use the default_gray template. I have found that it's necessary to copy the rank images from the default_ex folder to the default folder.
As far as simultaneous installation of Kunena and Fireboard on a single website is concerned, I have it on good authority that you can't do that. Uninstall Fireboard.
17 years 3 months ago #26796 by Tanin
Well, I deleted the Fireboard and switched to default_ex template and image sets. It looks nice but I'm still recieving the same error on the ranks management.If the problem has no solution, well I'll wait :cheer: .
Thanks for the help Sozzled and Xillibit
