Important Forum View counter not counting!
17 years 2 months ago #27884 by Matias
Found the problem:
components/com_kunena/template/view.php line 155+:
//update the hits counter for this topic & exclude the owner if ($this_message->userid != $kunena_my->id) { $kunena_db->setQuery("UPDATE #__fb_messages SET hits=hits+1 WHERE id='{$thread}' AND parent='0'"); $kunena_db->query(); }
Should be:
//update the hits counter for this topic & exclude the owner if ($kunena_my->id > 0 && $this_message->userid != $kunena_my->id) { $kunena_db->setQuery("UPDATE #__fb_messages SET hits=hits+1 WHERE id='{$thread}' AND parent='0'"); $kunena_db->query(); }
17 years 2 months ago #28229 by JTM369
I have tried your solution however, after testing it out by leaving a post on my site as a guest the following error message appeared.
Parse error: syntax error, unexpected '>' in /home/truththe/public_html/components/com_kunena/template/default_ex/view.php on line 156
I can not work out what the problem is.
Thanks again for your help.
17 years 2 months ago - 17 years 2 months ago #28233 by xillibit
I think the error comes from to a space, I don't know why : $kunena_my- >id and $kunena_db- >setQuery just after, remove the the spaces into the two things and this should works, like below.
//update the hits counter for this topic & exclude the owner if($kunena_my->id > 0 && $this_message->userid != $kunena_my->id) { $kunena_db->setQuery ("UPDATE #__fb_messages SET hits=hits+1 WHERE id='{$thread} ' AND parent='0'"); $kunena_db->query(); }
Last edit: 17 years 2 months ago by xillibit.
17 years 2 months ago #28269 by mrtn
Still no luck from my end unfortunately, the post view count still doesn't work after making above modification... Any idea why it might be?
Cheers
17 years 2 months ago #28629 by mrtn
BUMP
Come on guys I know you knwo how to fix it
