Question Avitar Upload Problem
17 years 4 months ago #23103 by WrongWay
Hi all,
Im basically a Joomla beginner and have installed version 1.5.1 and I have installed the Kunena forums latest version. When trying to upload a avitar picture, I can navigate to the upload field on the profile tab but when I click the "upload" button, Im re-directed to a garbled html looking page, solid white with only highlighted links for the profile. I uploaded the Kunena component via .zip file and maybe theres a problem with the original upload? Im clueless, can someone direct me to the proper documentation or maybe someone already knows the solution for this?
Thanks!
17 years 4 months ago - 17 years 4 months ago #23105 by sozzled
Replied by sozzled on topic Re:Avatar Upload Problem
Are we discussing Joomla 1.5.1? I know nothing about that version, sorry.
Perhaps this discussion topic might be helpful: Avatar upload doesn't work
Last edit: 17 years 4 months ago by sozzled.
17 years 4 months ago #23110 by Matias
Replied by Matias on topic Re: Avitar Upload Problem
Can you please provide a screen shot or a copy of the broken page?
Does enabling debug mode in Joomla give red error page? If it does, can you provide the information to us?
17 years 4 months ago #23165 by jimmykirk
Replied by jimmykirk on topic Re:Avitar Upload Problem
Your version of PHP, if it's less than 5.2.1, does not support the function "sys_get_temp_dir".
What you can do as a fix if you don't want to compile 5.2.1 or higher and re-install, is you can put the following in about line 27 on the file
/components/com_kunena/template/default/plugin/myprofile/myprofile_avatar_upload.php
right after...
"require_once(KUNENA_PATH_LIB .DS. 'kunena.file.class.php');"
if ( !function_exists('sys_get_temp_dir')) {
function sys_get_temp_dir() {
if (!empty($_ENV)) { return realpath($_ENV); }
if (!empty($_ENV)) { return realpath( $_ENV); }
$tempfile=tempnam(uniqid(rand(),TRUE),'');
if (file_exists($tempfile)) {
unlink($tempfile);
return realpath(dirname($tempfile));
That will fix the problem in the mean time.
Cheers m8,
Jimmy
17 years 4 months ago #23212 by Matias
Replied by Matias on topic Re:Avitar Upload Problem
In that require there's a call:
CKunenaPath::tmpdir() which can be used to get around of this bug.
This bug is fixed in K1.5.4, which will be released in few hours.
17 years 4 months ago - 17 years 4 months ago #23285 by WrongWay
Replied by WrongWay on topic Re: Avitar Upload Problem
Here's a shot of what I receive after selecting a photo to upload for the avitar and then clicking upload.
Last edit: 17 years 4 months ago by WrongWay. Reason: attachment fix
