- Thank you received: 2
Question Problems with loading forum after installing php5
Im running php4 so far and i want to try out Kunena 1.5.3. - I need to install php5 or else kunena 1.5.3 wont work.
But when im installing php5 my template wont load/work. The problem is only when the forum should load, all other times the template loads normally.
The problem is there with both versions of kunena 1.0.10 and 1.5.3. - so it might be some php5 attunements i need.
Can you guys/girls help me out??
Regards Jakob
What template do you use ? What php version do you use ?
Have you an error which is displayed ? Do you have tried the template default_ex for see if you have the same problem ?
Template is Whyld by James Spencer.
Im using php 4.4.7
It makes the same error in rhuk_milkyway
But when im using php 5.2 it wont load the template like the above picture. Same problem in Whyld and rhuk_milkyway
regards Jakob
Sorry for the reply's and not the edits, but seems like something is wrong..
/Jakob
What kunena template do you use actually ?
