Question Very rare problem v1.5
17 years 5 months ago #20462 by Cookedmeal
Well i started to install this version as a testforum.
test forum 2
And i don't know why it doesnt shows the template of the forum.
If i go to the admin panel of it, go to edit CSS file, it said this:
* JFTP::write: Bad response
* JFTP::delete: Bad response
Warning: fileowner() [function.fileowner]: stat failed for /tmp/9067b3a7db097f28ea496485673384bb in /home/ecomarath/domains/eco-marathon.nl/public_html/components/com_kunena/lib/kunena.file.class.php on line 53
Warning: filegroup() [function.filegroup]: stat failed for /tmp/9067b3a7db097f28ea496485673384bb in /home/ecomarath/domains/eco-marathon.nl/public_html/components/com_kunena/lib/kunena.file.class.php on line 54
Warning: fileowner() [function.fileowner]: stat failed for /tmp/b4ee87e86b69045dacba778820fc26bc in /home/ecomarath/domains/eco-marathon.nl/public_html/components/com_kunena/lib/kunena.file.class.php on line 53
Warning: filegroup() [function.filegroup]: stat failed for /tmp/b4ee87e86b69045dacba778820fc26bc in /home/ecomarath/domains/eco-marathon.nl/public_html/components/com_kunena/lib/kunena.file.class.php on line 54
Warning...
CSS file to be modified: /home/ecomarath/domains/eco-marathon.nl/public_html/components/com_kunena/template/default/kunena.forum.css
You need to CHMOD this to 766 in order for the file to be updated.
The CSS sheet is in there, but wtf is that ^ :(
17 years 5 months ago #20516 by xillibit
Replied by xillibit on topic Re:Very rare problem v1.5
I have never seen this kind of problem before, do you have checked this :
17 years 5 months ago #20605 by Cookedmeal
Hi Xilli,
Yes, i saw that CHMMOD and downloaded it.
I looked through Google for more info about that programm.
It said that this CHMOD is only working for Linux, but I have Windows Vista in use at this moment.
17 years 5 months ago - 17 years 5 months ago #20608 by xillibit
CHMOD isn't a program, read this : en.wikipedia.org/wiki/Chmod , if you have a FTP client like FileZilla you can set CHMOD with this, you can read this : www.phpjunkyard.com/ftp-chmod-tutorial.php
Last edit: 17 years 5 months ago by xillibit.
17 years 5 months ago #20711 by Cookedmeal
Ok, if i have any problems with this, i bump this topic again :side:
Thanks.
17 years 5 months ago #20717 by Cookedmeal
Hey,
I put the css file to 766, but i don't see the template red or default.
eco-marathon.nl/nog-geen-officiele-forum
