Question [Solved] Login alteration problem
17 years 5 months ago - 17 years 5 months ago #20305 by Sebastien
I removed the kunena login as instructions here: www.kunena.com/forum/4-archive-support/6...ogin-alteration#7597
the problem now is that the yoo login module appears on a vertical position and not horizontal. can you help me and tell me why? i have attached the problem in screenshot
Attachment problem-20090617.zip not found
Last edit: 17 years 5 months ago by Spock.
17 years 5 months ago #20338 by xillibit
in the module parameter choose for style : Nifty Quick, it's strange that the module isn't displayed under the welcome guest. Do you have set the position : kunena_profilebox ?
17 years 5 months ago #20385 by Sebastien
Yes. I have set it in kunena_profilebox position and it is nifty quick...please, help me guys...it is very strange
17 years 5 months ago - 17 years 5 months ago #20394 by Spock
Replied by Spock on topic Re:Login alteration problem
EDIT At this point I had misunderstood what Sebastien meant in his post above (so next few posts are irrelevant). Please find the accepted solution for this workaround here
there are two solutions to this problem (that i'd suggest to try)
1. in the kunena.forum.css
change
#Kunena td.fb_profileboxcnt {
width:95%;
to
width:70%; FOR EXAMPLE
2. Go to profilebox.php which controls that area of the template
YOURSITE/components/com_kunena/template/default/plugin/profileboxprofilebox.php and increase the td width on line 147 of this file it 12% by default
<td width="12%">
Last edit: 17 years 5 months ago by Spock. Reason: Added solution link
17 years 5 months ago #20395 by Sebastien
<td width="12%">
There is no such line or such content on profilebox.php
17 years 5 months ago #20399 by Spock
:huh: I do apologize that was a version that i had altered earlier that i was looking at. If you change
<td>
<div class = "fb_profilebox_modul">
<?php
$document = &JFactory::getDocument();
$renderer = $document->loadRenderer('modules');
$options = array('style' => 'xhtml');
$position = 'kunena_profilebox';
echo $renderer->render($position, $options, null);
</div>
</td>
to
<td width="50%"> [again for example]
<?php
</div>
</td>
this has to be done to both tables (lines 147 & 193)
