Before posting new topics in this category K 1.5.x Support: Please read this first.
Question Please help me i can open, view and post in a categorie from my website forum why?
16 years 1 month ago #60576 by nayanach
Is not the template befor wirks good but i was remove this from table os_fb_message too to view if works i think if i remove the post in database than works but not.... and now i have to unistall and install everything again? i lost all my forum? becouse the moust important categorie is this... and don't works...
"i will build kunena themes too soon"
regards
16 years 1 month ago - 16 years 1 month ago #60577 by sozzled
If you removed records from the jos_fb_message table, you will get Invalid Post ID responses in Kunena. Best suggestion I can make is to restore your forum/site from the last good backup you made. :)
Last edit: 16 years 1 month ago by sozzled.
16 years 1 month ago #60578 by nayanach
But before i remove i get this messages...
but ok i was make the question is and now? is not possible to fix?
16 years 1 month ago #60579 by nayanach
Better is not the first time i get this messages... i was remove becouse i think if i dont have this message more in database then is finish now what i need to do to remove this post ID?
HOW IS POSSIBLE TO FIX THIS OR IS NOT POSSIBLE?
IF NOT CAN I GET LL MY POSTS TO IMPORT TO A NEW INSTALLATION?
16 years 1 month ago - 16 years 1 month ago #60580 by sozzled
nayanach wrote: But before i remove i get this messages...
I don't know because I really don't know what you've done. If you got into the SQL database and changed things then you've probably caused the problems that you've now got. Unless you know what you did (and maybe help us to better understand what you did) it's difficult for us to help you.
Please see How To Destroy your forum data...
16 years 1 month ago #60581 by nayanach
Ok thank you... the post is not possible to export? i will install a forum i will ready about foruns...
