Question allignment on reply
16 years 5 months ago - 16 years 5 months ago #49498 by tjmartin
allignment on reply was created by tjmartin
Sorry if this is a duplicate post, but i have not found a solution to my issue. I am current on my Joomla install and Kunena install. When someone replies to a post, the emoticans on the side are alot lower than they should be for some reason. I attached an image for your review. The site can be seen at www.recongaming.net and select community forums. i would appreciate any help on this...i would hate to have to delete this and try another forum version.
Last edit: 16 years 5 months ago by tjmartin.
16 years 5 months ago #49507 by sozzled
Replied by sozzled on topic Re: allignment on reply
Please upgrade to K 1.5.11 to fix a number of known formatting problems with the version of Kunena that you have installed on your site.
Secondly, if the problem still persists after you have upgraded, we will require a test account access to your site to examine what happens when users try to create a message.
16 years 5 months ago #49512 by tjmartin
Replied by tjmartin on topic Re: allignment on reply
i have updated the forum to the most recent version and it is still showing the same issue. i have set up a temporary account login is testuser and pass is testpass.
The emoticons are down below still like in the above image. not like they are here on this site.
Thanks for your fast reply and I hope you can figure it out.
16 years 5 months ago #49513 by tjmartin
Im sorry, i just realized that it is not your software that is the issue. It is in the theme or template that is causing the issue. I understand that you do not provide support for other templates. if you could please give me insight as to where i may look for the issue, i would greatly appreciate it.
16 years 5 months ago #49514 by sozzled
No problem. I suggest you look at Before you ask for help with template issues ... which provides a lot of clues on how you can go about solving your particular problem. We always encourage our users to search for their own solutions and to use their own time and resources to learn about the magic of webcraft but, sometimes, the answer eludes them.
I had a quick look at your problem (thanks for providing the account information). What you need to do is to change your Kunena template at around line 59 and add the line in red below:
#Kunena tr.fb_sectiontableentry2 td {
background:none repeat scroll 0 0 #171717;
border-color:#2F2F31 #111111 #0E0E0E #2F2F31;
border-style:solid;
border-width:1px;
color:#CCCCCC;
padding:5px;
vertical-align:top;
16 years 5 months ago - 16 years 5 months ago #49515 by tjmartin
I totally understand and I apologise for my overlooking this. It had been awhile since i installed this forum as I was building the rest of the site. I appreciate your looking into the issue for me and that did the trick. Again..Thank you
Time to create page: 0.174 seconds
