Question Forum description and header not appearing in front-end
16 years 6 months ago #48759 by davidra
I'm using the latest Kunena stable release. Using the backend admin panels, within the Edit Category/Forum screen, I have written text in the name, description and forum header fields.
However, when I use the forum, these fields are not visible....just the white space where the text should be . I can however drag my mouse across this white space and can see that the text is there...its just not showing.
I think its a font colour issue - the font for these 3 fields must be white so they're not showing against the white forun background.
How do I find out... and where do I find the definition for these fields so i can change the font colour. If I change the font colour for these 3 fields - is there a knock-on effect else-where...is this font definition used anywhere else ?
Many Thanks
David
16 years 6 months ago #48770 by Cerberus
please retest using the default_ex template as that is the only one support by the moderators here. :)
16 years 6 months ago #48773 by davidra
Many thanks for the quick update however the default_ex template is being used
16 years 6 months ago #48775 by Cerberus
i can tell from your picture that is NOT the default_ex unmodified template, please use the default_ex unmodified template and test again.
16 years 6 months ago #48778 by davidra
This morning I had 1.0.9 installed but within the last few hours, I uninstalled this version and installed the latest version. From the backend, here is what is being set. It does say default_ex...are you thinking my yootheme template is interfering with the font setup ?
16 years 6 months ago #48794 by sozzled
Yes, from the description you've given of your problem, the cause lies in your Joomla template. I'd like you to have a read of I think that you'll find the answers that you are looking for in there .
I'm very pleased to hear that you have upgraded to K 1.5.11! :)
