Question Forum description and header not appearing in front-end
However, when I use the forum, these fields are not visible....just the white space where the text should be . I can however drag my mouse across this white space and can see that the text is there...its just not showing.
I think its a font colour issue - the font for these 3 fields must be white so they're not showing against the white forun background.
How do I find out... and where do I find the definition for these fields so i can change the font colour. If I change the font colour for these 3 fields - is there a knock-on effect else-where...is this font definition used anywhere else ?
Many Thanks
David
I'm very pleased to hear that you have upgraded to K 1.5.11!
