Question Problem with smilies and border [SOLVED]
16 years 6 months ago #47210 by Ke_Garnett
Thanks for your help, I've created an account for you:
Username: Cerberus (I send your pass via PM)
My Site
You can login at the top @button "Anmelden" Do know if you are fit in German ;-)
After login go to Devils Lounge, where my board is located.
Your idea is already good, it would be a real alternative, but @mom I'm looking for a borderless smilie solution, but thanks for the hint. You mentioned that you moved your smilies to the boardcodebox, how did you made this? This would be an alternative too. Many many thanks, mate.
Cheers
Thorsten
16 years 6 months ago - 16 years 6 months ago #47212 by Cerberus
ok this is how i have managed to do it using Firebug.
the only way i managed to get the smiles with no border and leave borders for the rest was to define border: none; on each line for the smiles in the HTML of the page. maybe not best way but only way i could find.
find the file that contain the smiles code it will look like this
<td style="cursor: pointer;" onclick="bbfontstyle(' :-) ','')"><img border="0" title=":-) " alt=":-) " src="http://www.manchester-utd.de/components/com_kunena/template/default_ex/images/german/emoticons/laecheln.gif" class="btnImage"></td>
and add the border define below to each smiles code
<td style="cursor: pointer; border: none;"
you mite want to do this on line 903 of your kunena css too
add text in RED
Kunena div.fb_message_editMarkUp_cover {
border-bottom:0 dotted #CCCCCC;
margin-left:5px;
padding-top:10px;
padding-top:5px;
text-align:right;
that will sort you message buttons appearing over you report to moderator link :)
Last edit: 16 years 6 months ago by Cerberus.
16 years 6 months ago #47225 by Ke_Garnett
Good morning mate,
thanks for your reply and help. Unfortunately it dosen't fit, cause the this code is generated dynamic, so it would hard to find for me, my first try was the search in the message.php, which should define the classes of the messageview (in my opinion). But haven't found anything yet, but I'm still looking to solve the problem ;-)
I used phpBB3 for a long time and there are indeed html-files at the templatefolder to define new classes etc, so it would no problem to change classes etc., but I took it down, phpBB3 got a lot of problems when you want to integrate it in Joomla. A bridge for the MySQL will work, but a visual Integration is not really simple, I would say a 1o1 visual integration is not possible @mom. And of course if you are working with SEF's, like me, it would be a huge problem too. So I decided to use Kunena, and I love it ;-) But I'm not so fit @Kunena at the moment ;-) But I'm still learning.
Anyways, I will look for a solution, but if I don't find a way through, I think I will follow your good advice and take the borders in messageview too. You mentioned, that your smilies are in the boardcodebox, are they still there on first view or have you to click on more smilies to make them expandable, like the original behaviour is? Many many thanks for your help and if I could help you too, let me know. :)
Cheers
Thorsten
16 years 6 months ago - 16 years 6 months ago #47246 by Cerberus
its more likely to be post.php file or smile.class.php file that are located in teh DEFAULT template directory.
what version of kunena do you have installed ???
16 years 6 months ago #47249 by Ke_Garnett
Ahh, got ya. It's the smile.class.php, I found the class definition. I will alter the class entry and make new css def's for that. Many thanks, now I know where I've to change the definitions. Many many thanks, I didn't found these files cause I've been looking at the default_ex folder not at default. May be I'm going to be more confused these days, ;-) I will post my solution.
Cheers
Thorsten
P.S.: I'm using 1.5.11
16 years 6 months ago #47252 by Cerberus
you will be even more confused soon when K1.6 is released as the template system is completely different lol
