Question joomla issue or kunena?
16 years 7 months ago #46209 by chicaloca
hi
I've looked through the FAQ about templates and searched the forum but don't seem to have come up with a definitive answer. I've installed the latest version of kunena (1.5.11)but having trouble with the display.
kds.dkeenan.co.uk/index.php?option=com_kunena&Itemid=37
that is the link that should hopefully link to the forum section. after looking around on the forum I've been able to modify the joomla template so the appearance is better (i know the colour scheme doesnt match but I'll worry about that later) but it's still not doing what I want, it seems too narrow vertically and horizontally. I think I'm right but just looking to clarify before going round in circles as I seem to have done all the way through the creation of this site! any nudges in the right direction would be appreciated.
16 years 7 months ago - 16 years 7 months ago #46214 by sozzled
Replied by sozzled on topic Re: joomla issue or kunena?
Love it! :woohoo: First time I've seen someone actually use the Beez template!
OK ... down to work: I only see one problem and it has nothing to do with Kunena. The Kunena display looks good to me (using Firefox or Internet Explorer 8) - I don't understand what you mean by too narrow vertically and horizontally - it's about right in terms of white space. But you do need to make the search intput-box accessible. Change the value shown below (at around line 211 of ../templates/Beez/css/layout.css):
#header form .inputbox {
background:none repeat scroll 0 0 #FFFFFF;
font-weight:bold;
margin:3px 10px 0 0 !important;
padding:0 0 0 2px;
width:6em;
You might also find these articles helpful: If I've misunderstood what you mean by "too narrow vertically or horizontally" perhaps you might like to show us, with a screenshot, how the display looks to you? What browser, for instance, are you using?
Cheers
Last edit: 16 years 7 months ago by sozzled.
16 years 7 months ago #46217 by chicaloca
thanks for the quick reply and glad you like it! pretty new to web development but learning all the time! :lol: funny you should mention the search box, just posted in a joomla forum about it!
#header form .inputbox { background:#fff; font-weight:bold; padding:0 0 0 2px; /* margin:20px 10px 0 0 !important; */ margin:5px 5px 5px 0 !important; /* see how the margin right below works */ margin-right: 25px; width:10em; }
in case you're interested thats my code for it now although the margin-right doesnt seem to do anything to centre it...
anyway sorry my description wasnt the best, i just meant that the whole forum looked a little squashed (such a technical term i know! :laugh: ) but seeing as this is the first time I've used kunena I'm not sure if this is show it should appear.
thanks for the links yeah I've had a wee peek at them before, once I get the layout just that little bit better I'll get working on the colour scheme :)
16 years 7 months ago #46218 by sozzled
Within the context of the Beez template, the position of your component display (the area that is used by Kunena) seems about right. To me it looks "centred" with just the right amount of white space surrounding it. Kunena will display differently - sometimes it won't work at all! - when you use other Joomla templates. If you want Kunena to appear wider, choose a wider Joomla template (like JA_Purity, for example). :)
16 years 7 months ago #46222 by chicaloca
ok thanks will do :) i take it that wont have much affect on my colours etc? thanks for your help always good to have a friendly font :):)
16 years 7 months ago #46394 by chicaloca
I've had a look at the JA_purity and you're right the forum looks much better on there. Is there a quicker way to modify the css so it looks more like the beez template or is it just a case of going through it all from scratch? just when i thought i was nearly finished....!
