Kunena 7.0.8 Released
Question K 1.5.9: BBcode issues: images not displayed inline with other images or with text
- theprofessor
You can see my issue here: schoolyourpool.com/message-boards/13-head-office
Images are aligning vertically instead of horizonatally. I know this used to be common with older versions of Kunena, but should this be an issue with 1.5.9?
Any ideas of how to fix?
Because you are using a specific kunena template , it will be more difficult to determinate the source of the issue.
- theprofessor
The problem persists if I use the 3rd part template or the default_ex template.
So, I'm thinking the template is not the issue?
I am currently using Kunena 1.5.9 and Joommla 1.5.15
remove the </div> statements untill the last image and then ur sorted..
if you want to post ur code and i will edit it for u
The
As you know, There is only one endorsed and supported Kunena template ... default_ex . You stated that your image alignment problem persists when you use the default_ex template. I should like to see that. If this is the case then I would be suspecting that there's this image alignment condition is being controlled by your Joomla template.
Now that I've got the preliminaries out of the way, you may need to discuss your problems with the developer of the defaul_ex_formality_gay_left template or retrofit the changes brought about by K 1.5.9 to that template yourself. This may or may not address the problem as I suspect it's your Joomla template at the cause of things. Some useful tips are contained in Before you ask for help with template issues ... .
- theprofessor
I have switched the template to default_ex so that you can see that the issue still persists.
Cerberus, here is the code that I am using:
The weird thing is that I actually had this working on Kunena 1.5.6. But then I upgraded to Kunena 1.5.10 on the day it was released. It worked then as well. I downgraded to 1.5.9 when it was revealed there were issues with 1.5.10. Since then I have had this issue. I tried 1.5.6 again but the issue persists.
Strange.
