Question odd forum display error
16 years 8 months ago #43488 by Cerberus
for some reason since i put k1.5.10 on my site i have been getting this odd error
i have the dark template on and i tried it with default template and doesnt seem to do it can any smart ppl here find me a fix.
p.s. doesnt do it in firefox only seems to happen in IE
come on sozzled help me out :)
16 years 8 months ago #43492 by sozzled
Replied by sozzled on topic Re:odd forum display error
You want me to get motivated to sort out IE problems? You must be kidding! :P But, seriously, I'll have a look at this very soon. BTW, does the issue disappear with IE 8 run in "compatibility mode"?
You are of course aware that a decision has been made by the developers to only ensure Kunena is compatible with the latest release of IE? In other words, at the time of writing, future versions of Kunena will not be made to be compatible with IE 7 or earlier; if Kunena work with those older versions, consider that to be good luck, not good management! I can dig out the reference to that decision, if you want.
16 years 8 months ago - 16 years 8 months ago #43494 by sozzled
As your explanation states, "there is a problem when you mouse [hover] over [various] buttons". As a guest browser, of course, I do not see any buttons. I would need to have the same level of access that you need to reproduce the problem at your site.
Would you like to PM me the information (URL, account name and password), please.
Again, as whenever I refer to the things you should know , we can't make any guarantees that we can always fix your problems.
Last edit: 16 years 8 months ago by sozzled.
16 years 8 months ago - 16 years 8 months ago #43497 by Cerberus
Replied by Cerberus on topic Re:odd forum display error
dw worry about that message itself that i already fixed its the odd forum size thats my issue.
will try the compatibility mode and its IE8 im having issue on :)
EDIT: yer works fine in compatibility mode but not standard IE8
see ur pm for login info and url..
Last edit: 16 years 8 months ago by Cerberus.
16 years 8 months ago #43501 by sozzled
Thanks for the information. I'm still browsing.
I seem to recall that there was, once upon a time, a problem when users posted a video link or, rather, a badly-formed video link. The consequences of that was to break the display.
From what I can tell, the "odd forum display" seems to occur only with selected topics, not with all of them. Is that correct?
Here's a suggestion. What happens if, in the link to the topic you gave me, you edited the post with the embedded video, and see what happens to the rest of the post.
(I could be barking up the wrong tree - that was an intentional pun aimed at Cerberus (a three-headed dog) - or it might be the clue. I don't know. More investigation. I will write back.
16 years 8 months ago #43502 by sozzled
No. Let me retract that last comment. The maligned Kunena display is unaffected by embedded videos. The problem seems to occur everywhere.
