- Thank you received: 71
Question odd forum display error
You are of course aware that a decision has been made by the developers to only ensure Kunena is compatible with the latest release of IE? In other words, at the time of writing, future versions of Kunena will not be made to be compatible with IE 7 or earlier; if Kunena work with those older versions, consider that to be good luck, not good management! I can dig out the reference to that decision, if you want.
Would you like to PM me the information (URL, account name and password), please.
Again, as whenever I refer to the things you should know , we can't make any guarantees that we can always fix your problems.
will try the compatibility mode and its IE8 im having issue on
EDIT: yer works fine in compatibility mode but not standard IE8
see ur pm for login info and url..
I seem to recall that there was, once upon a time, a problem when users posted a video link or, rather, a badly-formed video link. The consequences of that was to break the display.
From what I can tell, the "odd forum display" seems to occur only with selected topics, not with all of them. Is that correct?
Here's a suggestion. What happens if, in the link to the topic you gave me, you edited the post with the embedded video, and see what happens to the rest of the post.
(I could be barking up the wrong tree - that was an intentional pun aimed at Cerberus (a three-headed dog) - or it might be the clue. I don't know. More investigation. I will write back.
