Question kunena and articles side bar problem
- manansaini
- Junior Member
What version of Kunena have you installed?
ans: Kunena1.5.9
What Kunena template are you using?
ans: default_ex
What version of Joomla are you running?
ans: Version 1.5.15
What Joomla template have you installed?
ans: siteground
What is your site's URL. Does your site allow users who are not registered to view your forum? If your site does not allow users to browse your forum pages, do you have a test account that we can use?
ans: www.logicmatters.org
yes you can view without register.
Problem:::::
for showing kunena forum in full width i have to disable/uncheck sidebars for forum.
but when i disable side bars for kunena forum it also hides for articles
mean in articles also i m not able to see sidebars.
here is the screenshot:
It must be look like this with side bars:
- manansaini
- Junior Member
The "side bars" you refer to are the positions on your Joomla template to which you assign modules. This is basic Joomla function. You will find help on how to assign modules if you go to help.joomla.org/index2.php?option=com_co...w&id=1985&Itemid=278 and follow the instructions about Menu Assignment. In other words, you can assign modules to appear on all pages, on no pages or on selected pages of your site.
- manansaini
- Junior Member
that i read already, thats what i m saying i only disable modules for forum link in the sidebar but i also auto disable for articles
:( Please Log in or Create an account to join the conversation.
Simple yes or no: Do you know how to select a page, or several pages where you want your left/right modules to appear? :dry: I know that you know how to select your modules to appear on all pages or on no pages. Do you know how to select for specific pages?
- manansaini
- Junior Member
i unselect the forum link under the "topbar" menu.
img30.imageshack.us/img30/3448/80385897.jpg
