Question Problem Installing Numinu Template
17 years 3 months ago #26219 by chellige
I recently installed the numinu template (v1.0.3) into my /var/www/html/components/com_kunena/template/numinu directory. The owner of all files is apache. When I attempt to select the new template from the "Kunena Configuration Panel" the template does not appear in the drop-down list for "Template" however it does appear in the drop-down list for "Image Sets." Can anyone please tell me where I went wrong?
17 years 3 months ago #26226 by @quila
Hi chellige,
can you tell me what is exact root to your numinu template?
components / com_kunena / template / numinu / image
or
components / com_kunena / template / numinu / numinu / image
Thank you
Regards
17 years 3 months ago #26233 by chellige
17 years 3 months ago #26239 by @quila
Hi again,
check if you have the file kunena.forum.css iside numinu folder
Regards
17 years 3 months ago #26257 by chellige
No I do not. There is a forum.css. I tried renaming the forum.css file to kunena.forum.css and that did solve the initial problem, now the Numuni template showes up in the drop-down list however when I try to use it I get the following error when accessing my forum front-end:
Fatal error: Call to undefined function KUNENA_get_menu() in /var/www/html/components/com_kunena/kunena.php on line 477
17 years 3 months ago #26259 by @quila
it's not good to rename this file!
I don't know how is created this template but I think if you go to
{J! root} / templates / your_template_name / css /
you find there the file kunena.forum.css cut this file and paste inside numinu folder.
Regards
