Question inaccurate display with opera
do you use degault or default_ex kunena template.
If you use default try to switch to default_ex to see if you still have the problem.
Regards
But 1) I have customized my default_red with my own colours and icons. 2) would it not a real solution only change the template
Jens.
the problem of this template is not support from any one and you can have another problem with this template. From Kunena 1.6 this template don't be in download package any more.
Well if you have only this one problem with this template provide a link to your site and we can find a solution but if you have more problem, better way is to leave and customise default_ex.
Regards
still no, but the DEVs work on it.By the way: is there eny date for Kunena 1.6?
The next release will be 1.5.5
Regards
