Question Recent Posts section does not show in default_ex template
17 years 3 months ago #25033 by zazazi
I wonder if you can help me on this one.
For some reason, Recent Pots section does not show when I use the default_ex template...it shows with all other templates.
Thanks for your help
17 years 3 months ago #25036 by sozzled
The usual reason when this problem occurs is because you have another component that is conflicting. What other Joomla extensions do you have installed; what Joomla template are you using. Do you get the same situation when you use one of the "standard" Joomla templates (like rhuk_milkyway, for example)? :unsure:
17 years 3 months ago #25053 by zazazi
I'm using rt_chromatophore
I get the same problem when I use a standard Joomla template
Here is a list of my components:
eXtplorer
SectionEX
Joomap
JCE
JoomlaPack
I don't get this problem when I use any template other than the default_ex
Any suggestions?
17 years 3 months ago - 17 years 3 months ago #25055 by Lintzy
Sorry, I don't understand "Recent Pots section does not show"
What does this mean? You see not the tab, or you see the tab but the rest is empty? Or do you get an error message? :side:
A link to your forum would be very appreciated.
:woohoo: Idea! Do you mean this ? ->
This is a feature, that only exists in Template default.
Last edit: 17 years 3 months ago by Lintzy.
17 years 3 months ago #25057 by zazazi
YESSSSSSSSSSSSS this part does not show in default_ex template but shows in all other templates
17 years 3 months ago #25058 by Lintzy
Right, this is normal, no bug, the code to show recent posts is not integrated in default_ex template.
It does show only in default, default_gray, default_green and default_red <- these all are default templates. ;)
