Question need blue background and yellow text
17 years 4 months ago #24042 by deafeagle
I am a beginner.
I have use CSS editor to change all blue background and yellow pen because it is good for usher, and deafblind.
I change the white colour into blue colour.
Then I see results - disappointing because
first row is white
second row is blue
third row is white
etc
I want all rows are blue and yellow.
I search all in css editor not find.
I attach an image for example.
Please any templates with all blue background and yellow text.
17 years 4 months ago #24046 by Admata
Get and use Firebug. It´s a firefox plugin you can use to inspect your template piece by piece and see what CSS line affects where ;)
getfirebug.com/
17 years 4 months ago #24052 by deafeagle
i tried to look this program in joomla administrator and it does not look at kunena code that depth.
But thanks anyway.
Need blue background and yellow ink still.
17 years 4 months ago #24085 by deafeagle
How to resolve this issue?
Need to make all blue background to match the website all blue background.
17 years 4 months ago - 17 years 4 months ago #24086 by Lintzy
Admatas tipp was a very good one. With firebug getfirebug.com/ you can examine your website
and find the "class" or "ID" that is used.
Search for this class or ID in Firebug/CSS
and change the background-colour. You get a life view in Browser. If your changes are right, insert them into kunena.forum.css.
What you are searching should be fb_sectiontableentry1 and fb_sectiontableentry2 (and perhaps more classes or IDs, that are responsible for the background)
Last edit: 17 years 4 months ago by Lintzy.
17 years 4 months ago #24165 by deafeagle
Thank you very much.
I tried to use firebug and it does not display in kureau code ... only the main page, then i want them to analysis inside the box of kureau code - all black and white, not allow me to identify the code - perhaps I do something wrong. I search all white #FFFFFF and i replaced all into blue.
anyway I choose a different template that allow display all blue and yellow. It works now but new problems.
1. But some white still there especially the box (bottom) I do not know which code of white background need to change into blue.
2. when i type the post message, the subject is white and yellow ink.
3. forum header - are not white but something near white. do not know where the code is.
4. when press buttons - all white.
i will include all code in next message
