Question Weird Spacing Problem
17 years 4 months ago #24007 by Pocketss
I downloaded and installed the 'default_ex_black' template. When 'Categories' tab is active, there is a block of empty space between the profile box and the actual forums.
It's on the live site for the moment, if you want to take a look at it.
You can use the username and password below or register yourself, whichever you prefer.
Username: test
Password: test
I have tried to play around with firebug and see if it's a particular option that is doing that or what, but I can't make heads or tails about it.
Pocketss
17 years 4 months ago #24012 by sozzled
Replied by sozzled on topic Re:Weird Spacing Problem
It's difficult to see what problems you have (at offline.horribleoffline.com/ ) because
  1. You do not have any forum categories; and
  2. (obviously) you have no forum messages
. Why did you delete the original categories and test messages?
17 years 4 months ago - 17 years 4 months ago #24013 by Pocketss
Replied by Pocketss on topic Re:Weird Spacing Problem
Sozzled, i did delete the original category and message. Let me make a post test post in all the forums.
Edit: Okay I made post in the initial forums.
Once you click on 'Forums' from the main menu on the site, click on 'Categories' tab. You should see the problem.
Then you should scroll down, and you will see the forums.
Last edit: 17 years 4 months ago by Pocketss.
17 years 4 months ago #24014 by sozzled
This is the problem that I see
The fix for it will come, soon enough.
17 years 4 months ago - 17 years 4 months ago #24015 by sozzled
The problem is caused by your shout-box on that page. Its CSS conflicts with Kunena. I don't have a fix for it, yet.
EDIT: These changes to your Joomla template CSS will illustrate how to work around the problem on your forum
#left_out {
float:left;
margin:0;
padding:0;
position:absolute;
width:188px;
But this causes other problems with the rest of your site (e.g. your home page) - anywhere else that you use the shoutbox.
Last edit: 17 years 4 months ago by sozzled.
17 years 4 months ago #24160 by Pocketss
I am going to start from scratch and see where i end up. Thank you for your help again sozzled.
