Question Change default_grey link color
17 years 4 months ago #23818 by jennmitch75
I was wondering if someone could tell me how to change the link color in the defaut_grey template. I am a newbie with css. I changed the hover but not the main. Thanks.
Jen
17 years 4 months ago #23861 by sozzled
There is little or no support offered for the default_grey template because little or no development work has been done with it since Kunena 1.0.8. These days the default_grey template is a bit of a bug-ridden curiosity. Users are strongly encouraged to use the default_ex template; next, in order of preference, is the default template - the default template will probably be phased out over time. Other templates included in the installation kit, and those created by users here, are the use-at-your-own-risk variety.
Unless I loaded the default_grey template on one of my test systems, or saw it in action (on your website, for example), I don't know where to begin to answer your question. Sorry.
17 years 3 months ago #25197 by Lintzy
Did you find a solution in the meantime?
It is not recommend to use the default templates. Kunena has only one working template this is default_ex.
If you want to make changes to CSS, you will find here a tutorial how to do this:
docs.kunena.com/index.php/Changing_Templ...Colours_-_the_Basics
