Question How to resize forum size??????????????
17 years 4 months ago #22729 by TIIAdmin
Hello.
My website template was made by me so did i mess up when making the template or it just the size Kunena that making my forums look like this
I want to be full sized how do I do that.
Please Response ASAP
Thank You.
17 years 4 months ago #22745 by sozzled
I've seen your question asked many times. Sometimes the problems occurred because users changed the kunena.forum.css file, sometimes they were caused by using an unsupported Kunena template, but most of the time they resulted from using a lousy Joomla template.
There's always one easy way to see if Joomla is involved: try using the rhuk_milkyway or JA_Purity template (it doesn't matter whether or not you like them). If your forum is no longer small, you know where to focus your effort, don't you?
I don't know the answer in your case. I am sure, though, that if you search this forum, using terms like "my forum is too small" or "how can I change my forum size" or a couple of keywords, you will find something helpful. Or you can wait (maybe several days or weeks) before someone is able to diagnose and rectify the problem on your behalf. The choice is yours. :)
17 years 4 months ago #22817 by Lintzy
Hi TIIAdmin,
did you set the
<?php if($this->countModules('condition')) ?>
correct in your index.php? ->
portal.hrpr.com/joomla-15-templates-conditional-statements
If this is not the reaseon, please post a link to your forum, perhaps it can be solved with css.
17 years 4 months ago #22875 by TIIAdmin
It the Template problem any one here know where i can get good template for free.
17 years 4 months ago #22876 by Spock
I've been impressed by www.joomlaxe.com templates - just my opinion though
17 years 4 months ago #22883 by TIIAdmin
I made my templates with aritsteer looks like they not that good it doesn't adjust from page to page it just stay there like other Templates adjust from page to page it just follow it the design did any one here know what i am doing wrong and tell me how to fix my error
