Question [Solved] Icons not in a row, help!
17 years 5 months ago - 17 years 5 months ago #20221 by barthle
I just upgraded to 1.5.3
Everything looks OK so far except one little template issues. Buttons are expanding into the next message space for admins.
I tried to use Lintzy's hack below for displaying them in one row. It worked but had a side effect: avatars of the user's in the thread disappeared. I guess the following hack doesn't work in 1.5.3
www.kunena.com/forum?func=view&catid=6&i...view&catid=6&id=4327
How can I adapt this hack for displaying the buttons in one row for 1.5.3?
Last edit: 17 years 5 months ago by barthle.
17 years 5 months ago #20231 by @quila
Hi barthle,
can you provide as a link to you forum then we can look?
Regards
17 years 5 months ago - 17 years 5 months ago #20237 by barthle
Hi Quila,
I really don't know what I have changed but now it looks OK.
But the buttons are still in two rows. How can I show them in one row?
here is our site:
www.e-hayalet.net/index.php?option=com_kunena&Itemid=453
17 years 5 months ago #20239 by @quila
Hi barthle,
only admin and moderators have buttons in two rows.
If you still want to show them in one row find the file
/components/com_kunena/template/default_ex/message.php
line 368 change this
if ($is_Moderator) echo ' </div><div class="fb_message_buttons_row">';
with this
if ($is_Moderator) /*echo ' </div><div class="fb_message_buttons_row">'*/;
Regards
17 years 5 months ago #20240 by barthle
Thank you very much Quila. That worked. Regads
17 years 5 months ago - 17 years 5 months ago #20252 by Spock
just merging these two threads - both ask the same thing and have been solved
Last edit: 17 years 5 months ago by Spock.
