Question Removing tabs
16 years 4 months ago - 16 years 4 months ago #53091 by JackJJW
Removing tabs was created by JackJJW
Hello!
I love this forum software. Thank-you for making it!
I've installed Kunena and integrated it with a Joomla instal with Community Builder. So I don't really need the 'My Profile' tab on the forum as well as the main site navigation. Is there an easy way to remove this?
Thanks!
Jack
Last edit: 16 years 4 months ago by JackJJW.
16 years 4 months ago #53105 by @quila
Replied by @quila on topic Re: Removing tabs
Hi Jack,
can you say as what version of Kunena you are using. Thank you.
16 years 4 months ago #53204 by JackJJW
Replied by JackJJW on topic Re: Removing tabs
Hi @quila, it is 1.5.12
16 years 4 months ago - 16 years 4 months ago #53227 by Cerberus
Replied by Cerberus on topic Re: Removing tabs
you can remove it in ../components/com_kunena/template/default/plugin/profilebox/profilebox.php
i can not give you the exact line as i have removed all the tabs from my site but it is close to the top of the file just remove the my profile part. :)
Last edit: 16 years 4 months ago by Cerberus.
The following user(s) said Thank You: iPoo
