Important Need help changing some colour in my template please
16 years 6 months ago #49051 by sk1nlimited
Hi was wondering if someone could please help.
I am using a dark version template for kunena and a couple of things need changing in colour
the box where you select a file to upload, once you have selected a file to upload the text in the box is black and so is the box background colour - hence you cannot see if a file has been selected.
Also the indicator that shows on the forum when there are new posts ie (32NEW) is in red and i would like to change it to a light grey.
Any help would me greatly appreciated
regards
jay
16 years 6 months ago #49072 by sozzled
There's a lot more work involved here than I have time for at the present moment, so I'm going to offer you a suggestion while you are waiting for someone who has the time to help you:
If you use the time to learn how to drive Firebug for Firefox (while you are waiting for someone to help you) you might even solve your issues before someone else does. That would be a good outcome for you, wouldn't it? You might even be able to share your new work with the rest of the community. That would probably be an even better outcome! ;)
16 years 4 months ago #51668 by Oscar
And when you get really good you can start to help others on this forum and once you've learnt to be rude to people you might even be made a moderator
16 years 4 months ago - 16 years 4 months ago #51684 by Cerberus
The DARK template for kunena is not supported or written by the kunena project and to be very honest there is 3 possible template you could mean with teh term DARK template. so if you want me to be able to solve this for you i will need a link to your site and a login if it is set to registered users only...
Last edit: 16 years 4 months ago by Cerberus.
