Question Full Width Forum for JA_Edenite template
16 years 6 months ago - 16 years 6 months ago #47881 by dumbmage
Hi, I'm trying to interegate Kunena into my website but want it to use the full width of my website, however I tried to deselect Kunena from my Menus and but the column will not go away.
The problem is that I need to the column to be removed for forum but not for other parts of the site.
here's a screen shot.
thanks!
I tried to follow the guide on the wiki page but I didn't understand the tutorial.
Last edit: 16 years 6 months ago by sozzled. Reason: Changed subject to improve search relevance
16 years 6 months ago - 16 years 6 months ago #47887 by dumbmage
Replied by dumbmage on topic Re: Full Width Forum
File Attachment:
File Name: index.txt
File Size:11.76 KB
I have attached my template.
I am using 1.5.11 kunena
Last edit: 16 years 6 months ago by dumbmage.
16 years 6 months ago #47889 by xillibit
Replied by xillibit on topic Re: Full Width Forum
why you don't understand in the doc : docs.kunena.com/index.php/How_I_can_get_..._Forum_in_my_site%3F ?
16 years 6 months ago - 16 years 6 months ago #47893 by Moonstone
Replied by Moonstone on topic Re: Full Width Forum
If you've deselected Kunena in all your left modules and you're still showing an empty column, the only thing I can think of is that it's possibly a problem with your template?
For example, I've had issues with Siteground templates doing exactly what you're describing. They embed their logo into the bottom left column which prevents completely collapsing it. So, if you try to make your forum full width, you still end up with this empty column on the left.
No offense to Siteground. They create some beautiful templates. But that issue is quite annoying. >.<
Last edit: 16 years 6 months ago by Moonstone.
16 years 6 months ago #47894 by sozzled
Replied by sozzled on topic Re: Full Width Forum
dumbmage: The screenshot you showed does not look like the standard Kunena default_ex template. So, whose template is it? Maybe the designer of your Kunena template did not factor-in a full-width display for your particular Joomla site template? :dry:
And, while we're on the subject of Joomla site templates that don't support full-width displays when you try to use Kunena, Siteground templates are notorious for causing these kinds of problems.
We might be able to help but I think we're going to need access to your website to see what's causing the problem. Could you arrange access for us, please? :)
16 years 6 months ago #47895 by dumbmage
Thanks for the very quick replies guys!!
I tried to reinstall the compononet to get the default template back... but it seemed like it didn't work and I think I have to tweak some things in my Joomla Template (according to the FAQ)
I have pm'd you my site details.
Thanks!
