Question Problems with size in subforums
16 years 1 week ago #47400 by silversand
I have been setting up a site with Joomla and Kunena forum, but have encountered a small problem, the width of the forum "subject" category is very small when inside the forum, when selecting a subforum, the size is normal, but when inside, ready to post, it changes the size like the picture below.
How do i change it, so that the "last post" (Sidste post) gets moved out to the right again, where its supposed to be, so that the "Subject" (Emner) isn't so compact and unreadable.
16 years 1 week ago #47620 by sozzled
Your problem is caused by a clash between your Joomla site template and your Kunena forum template. It may surprise a lot of people to learn that the Joomla site template can override the CSS rules of other Joomla extensions used on your site. The Kunena CSS basically says, "if it's not defined in here, use whatever is used by the site template." So, if your site template displays plain text in a microscopically-sized font, don't be surprised if your Kunena forum font is similarly the same size.
Have a read of Before you ask for help with template issues ... If that doesn't answer your question then, by all means, ask. Good luck. B)
