Question Problems with new topic icons
16 years 1 month ago #46798 by silrem79
Hello all
I have a problem with new topic items, what I've added to my Kunena.
The first problem is, when I create a new post and select one of a topic icon, the icon is not taken and i can´t show it on the forums catagory. Only when i edit the post and select the icon again, it will be show up.
The second problem is, the alt tags for the icons in the post creation process (smile.class file) will not work.
My Kunena Version is the 1.5.9 .
Big thanks for feedback.
16 years 1 month ago #46799 by Cerberus
Current supported version of kunena is K1.5.11 please upgrade yout versiion of kunena and try again. If after you have upgraded you still have issue then post here and i will try and sort you out :)
16 years 1 month ago #46875 by silrem79
Hello Cerberus
Thx for the feedback. I have upgraded on 1.5.11 . There is no changing for both problems.
16 years 2 days ago #49933 by silrem79
Hello again
Does anyone have a solution to the problem?
Thx
16 years 2 days ago #49935 by fxstein
Are you using any third part SEO URL components?
If you have other components and plugins installed, can you try to disable them to narrow down the problem? This sounds like some sort of interference between something else and Kunena on your system.
16 years 2 days ago #49950 by sozzled
I have a suspicion that the user has a customised, non-standard or defective Kunena template installed. What Kunena template is being used? Can you provide a link to the website to help diagnose the problem, please? :)
