Question No white spaces between lines in posts
16 years 6 months ago #43722 by Lord Zedd
Hello there,
I am having trouble with my Kunena. When I create a new post or a new thread, I write my message. When I press the enter button to go one line below, it disappears when the post is published.
My message is for example :
Hello there.
My name is Lord Zedd
But it shows when posted
Hello there.
The problem is since 1.5.6 and am now using 1.5.9. Any help with this please?
16 years 6 months ago #43730 by Cerberus
wat template are you using for joomla and kunena ???
16 years 6 months ago #43822 by Lord Zedd
I am using the default ex.
16 years 6 months ago #43842 by sozzled
The cause of the problem lies within your Joomla template. I have a similar issue (not so much with Kunena, but with everything else) on one of my websites where the Joomla template appears to squeeze out line spacings. Solution? Fix your Joomla template or change it to something else. B)
Please also read: Before you ask for help with template issues ...
16 years 6 months ago #43885 by Lord Zedd
Hello Sozzled. The problem does not lie in my Joomla template because it did not had the problem in Kunenan 1.5.4 or 1.5.5. So where do I look than for a solution?
16 years 6 months ago #43897 by sozzled
